What is the best video creator?
Hello everybody,
What is the best video creator? I have 10 videos with a .mp4 file format, I am planning to edit all the videos and add some amazing effects to make it interesting. There are so many video editing software but I want an easy to use and compatible with windows xp operating system.
Thanks and have a nice day.
Best Answer by Cathrin Hopkins
Answered By 5 points N/A #184663
Hi there,
There are various software for video editing purpose. Here I list a few of them:
1. Avidemux is open source software. You can download it very easily and it is freeware.
2. If you are a newbie you can use VirtualDub. It is also a freeware which provides an excellent user interface.
3. You can freely download Wax and Blender for 2D and 3D effects.
4. Windows Movie Maker 2.6 can also be used as a freeware for editing videos in Windows XP.
Here I list some of the paid software which you can buy at very nominal cost and get excellent results.
1. The Corel VideoStudio Pro X5 is used for inserting 3D effects in our video.
2. CyberLink PowerDirector 11 Deluxe is used for trimming the videos, and it is well known in the field of film making.
Good Luck.
Answered By 5 points N/A #184664
Well there is a lot of software for editing video you may find in internet for download or you can buy from local.
I personally preferred Corel Video Studio Pro X5.
It provides all local requirements that can make you satisfy to do with videos, it’s user friendly then other software and works very fast with dynamic output, there have also some special effects with it.
You can download it in the link:
Or just go to Google search and type Corel Video Studio Pro X5 with free download.
