What is the best way to check computer hardware problems?
I use tester for memory testing and had generator for hard drive problem. What are the best and effective way to test a computer, mother, processor, video cards, etc.completely? Any software or hardware device?
Best Answer by jennysp
Answered By 0 points N/A #98450
There are many software out there where you can test your every component. For example, Ram uses Memtest86+ software. Search it on google. You will find it. For CPU, it is best to check the temperature of your CPU. There is built gadget in Windows 7 for checking temperature of your CPU, but if you don't have it then use mainboard monitor software. Again search it in Google you will find it. Now for hard drive, you can check by using software like IBM/Hitachi's Drive Fitness Test and graphics. There are benchmarking software out there like www.futuremark.com. I think this will help with your problem.
Answered By 0 points N/A #98452
Instead of doing all those open this site and choose any software to inspect your hardware.
This will save you a lot of time and energy –
Just to mention a few of the software: FreshDiagnose, BurnINTest, VSO Inspector, RightMark 3DSound, Parallel Port PIC Programmer and so many more; these inspect not only your hardware but also what you have installed.
They can guide you on the hardware or software to change or upgrade so as not to experience run time errors, hanging of the system, graphic card errors or windows or any other installer errors.
So my friend, discover which one is giving out good report concerning your hardware and software.
