What is the best way to convert wim to iso?
Hello experts,
What is the best way to convert wim to iso? Any software that will allow us to convert wim to iso will do. I have 30 wim files that need to be converted and I am hoping that you could recommend the best software which is compatible to my windows 7 starter operating system.
Thank you experts.
Best Answer by tipid_01
Answered By 0 points N/A #150514
Hi ,
As you mentioned you are using windows 7 so i prefer you to download windows automated installation kit from Microsoft downloads. You need to follow instructions during the install follow the below link so that you will get an idea.
http://www.microsoft.com/en-us/download/details.aspx?id=10333
Answered By 0 points N/A #150515
WIM=Windows IMaging is a compression format that was developed to be used after vista. To Convert follow these steps:
1. Download the Windows Automated Installation kit from the official windows site.
2. Make sure that the file from which you wish to make an ISO is located in the root c:/ directory. (Name it discovery.wim for ease of use) and then follow all the prompts to install the software
3. Open a Windows Preinstallation Environment and copy the WIM file into it; do so by typing "CopyPE <architecture> C:Winpe" to create the environment, then "Copy /y C:discover.wim c:WinpeISOSources" to copy the file into the environment.
4. Navigate back into the PETools folder by typing "Cd C:Program FilesWindows AIKToolsPETools.
Answered By 0 points N/A #150516
Hi Jay,
To be able to convert wim to iso, you just have to do the following:
1. Download first the Windows Automated Installation Kit from microsoft.com/downloads.
2. You also have to make sure that the wim file is located on the root c:/directory.
3. Open a Windows Preinstallation Environment and copy the wim file into it. Type "CopyPE <architecture> C:Winpe" to create the environment, then "Copy /y c:discover.wim c:WinpeISOSources" to copy the file into the environment.
4. The next step is to navigate back into PETools by typing the command: "Cd C:Program FilesWindows AIKToolsPETools"
5. The final step is to type "Oscdimg -n -bc:winpeISObootetfsboot.com c:winpeISO c:<imagename>.iso". This will create an ISO image from the contents of the Preinstallation Environment.
I hope each step is clear. Good luck!
Answered By 5 points N/A #150517
You will receive so many different answers on how to convert a WIM File to an ISO File. Most of these procedures turn out to be false. I always visit https://www.techwalla.com/articles/how-to-convert-a-wim-file-to-an-iso-file whenever I have a problem like yours. Trust me the steps are clear and easy to follow.
Good luck.
