Lisa Larsen
Posted on - 05/06/2013
I need to create a search engine homepage with custom icons in Photoshop and illustrator for a website I am developing. The site will contain web graphics Photoshop designs suggestions. What is the best software to install to be able to do that?
What is the best web graphics Photoshop software
I recommend you to use Adobe Photoshop CS6. It is easy to install and you can easily learn in creating some graphics stuff for your website like GIF files, icons, logos, and banner. You can also download different artistic brushes that can make your work look more creative and interesting. Designing a website and making graphical contents would be easy and fun with the use of Adobe Photoshop CS6.
You can try the new Photoshop CC. There are many new features that were launched on this photoshop which can help you to create or design  a web site. This Photoshop supports most intuitive and innovative enhancement that will improve design workflows. You can easily turn your web design into responsive websites and viewable across devices. You can download and check the other features here: http://www.adobe.com/products/photoshop.html
