What is the best Windows CE softphone?
Please recommend freeware and good Windows CE soft phone. I've tried this one program (never mind the brand) and it's terrible. Every time I start it the OS starts to crumble. I think it came with a virus when I downloaded it. I am considering license soft phone as long as it is of superb functionalities.
Best Answer by Goram Ian
Answered By 10 points N/A #191723
Hi Green,
SJphone is one you can rely on. It works on PC/PDA, any stand-alone IP-phone, or using Internet Telephony Service Provider (ITSP). For working with ITSP, you need a account. You can download it from http://www.sjlabs.com/sjp.html.
Terrcall is also now supporting VOIP for softphones. You can also try that.I hope this will helps you.
Thank you.
Answered By 60 points N/A #191725
Hi, Green Scott
There are a lot of good windows CE softphone. It depends on the site that your going to download it. I have attached a link below that leads you to a downloading site. It has 5 star reviews. I think it may help you choose the best CE softphone for you.
Hope that helps you a lot with your problem.
Thanks and more powers.
