What is the best yet simple game creator?
I need to have a simple game creator. Any software will do. Can you give me any suggestions? Where can I download it?
Hi Bettyjfrance,
There are a lot of game development softwares out in the internet.
This one is the easiest with no need for coding any sort and you get to publish your games – http://www.engine001.com/
But these games are limited to RPG types of games.
For a more dynamic style of games, I would suggest Adobe Flash, but it would require some knowledge of actionscripting and little animation. Anyways, here is the link to adobe flash cs6 – http://www.adobe.com/products/animate.html
PYTHON is a great language in game revolution, I would still recommend PYTHON programming learners because PYTHON has many advantages, It’s have many common stuff and libraries with built in moods, testing program, Optimizer. I suggest you must be read Sweigart’s Book for PYTHON Programming.
If you want PYTHON software you can find on the net easily.
Regards.
Notifications
