I’m not sure which one is better payroll simulation php script or java script? Tell me in detail why you are suggesting me to use that one.
Thanks
What is better payroll simulation php script or java script?
hi
i am giving you Both features of PHP scripts and Java Scripts. Mostly It depends on you whether to use PHP or JAVA.
PHP:
 PHP is a purpose scripting language that is usually suited to server-side web development where PHP runs on a web server.Â
It is free of charge, and the PHP Group gives the complete source code for users to create, customize and extend for their own use
.PHP acts basically as a filter, by taking input from a file or PHP instructions and outputting another stream of data; commonly the output will be HTML
.At least 20 million Internet domains had hosted on servers with PHP installed.
JAVA:
JavaScript is characterized in the ECMAScript language.Â
This provides programmatic access to computational objects within a host environment.
The most general use of JavaScript is to write functions that are embedded in HTML pages and that relate with the Document Object Model (DOM) of the page.
It is highly dangerous to insert important information such as passwords in JavaScript because it can be accessed illegally by an attacker.
