Goldie Bond
20 points
Posted on - 06/29/2012
Blackberry has an application called Viber that allows you to send messages anywhere in the world for free. Some give the app good reviews, while others rate it as a lousy app. Does blackberry have any other app that can send messages and call anywhere in the world for free?
What blackberry app allows you to call and send messages for free?
Yes, there are applications. But you will have to Google it in order to get a proper solution meeting with your required.
Also, there are some applications available in third party sites which you can try for free and certain settings of your device needs to be updated in order to use third party applications
Hope this would assists for you.
Hi Goldie, thank you for sending this in.
I gotto agree with you, about Viber being lousy and all. But it was back when it was first released in beta. But as time goes by, updates are definitely making the app better. I can now recommend you to still try Viber out. There are however, a few other applications. Whatsapp, for one, can do whatever Viber can do. I suggest that you give it a try as well. Hope this helps!
