What is that box that looks like barcode?
That square box you normally see that looks like a bar code is often used on mobile phones. It is called the “QR code” or known also as “Quick Response Code”. It is a mobile phone readable bar code or the mobile version of the usual bar code we see. This is often scanned using the handset’s camera to be able to access the record about the item linked to the QR code.
This is a 2-dimensional bar code that was first designed in Japan which is intended for the automotive industry. A bar code is an optical machine-readable label connected to objects that registers information associated to the object. It is very similar to the price tag sticker on the items found on the grocery store that displays the amount of the product. In QR code, it contains more information.
The QR code that became a big hit in Japan
                                            Great solutions guys! Thanks both of you. Often, we can see this funny looking square box which looks like a bar code but by reading your comments I have learned that its name is “QR code” or “Quick Response Code” . You enlightened that this is an optical machine-readable label connected to objects which registers information associated to the object which information were not known to me before. Thanks again for sharing this enhancing post.
