What brother mfl pro suite is?
Hi guys,
I have some brother hardware: printer and scanner. I want to know what brother mfl prosuite software is, and which hardware it supports. I use windows 8 64-bit professional.
Thanks
Hi guys,
Thanks
It is basically an installer of several programs to give you flexibility when you are using your Brother machine. I listed the programs included when you install it.
Windows
· Drivers (printer and scanner)
· Brother Control Center
· ScanSoft® PaperPort® with OCR and ScanSoft® PaperPort®
· Presto!® PageManager®
· True Type Fonts
Mac
Hello Tysons Harpe
Hope you are fine. MFL pro means Multi-Function Link pro suite. By this software you are eligible to install program for your entire hardware, scanner and Brother Control center. This software’s are available with your product CD. This CD will support your Windows XP 64 bit professional. Search the CD and run that in CD rom and follow the instructions. All of your software will be installed. Hope this will help you. In a word, MFL pro suite is an installation software collection for all of your Brother product.
With Thanks
Greaney Mary
Notifications
