What is Brother Pocket Jet Mobile Printer?
I heard a news about Brother Pocket Jet Mobile Printer. How small will it be?
If it is very small, how will it be helpful for the users?
What kind of mobile will be needed for it?
Hi Greg,
There’s this Brother PocketJet 6 Mobile Printer which is only 8 inches wide and only 1.4 pounds. Since it has a USB port it also gives a capability of being connected to a laptop / computer with compatibility to Mac and Windows OSes. For mobile, it supports Blackberry, Android and Symbian. Apart from the USB port infrared technology and Bluetooth is also an available option.
Mobility is one of its undoubted key features. But it is more tailor fit to companies and institutions with such mobilized printing needs, such as traffic ticketing, reports for emergency and accidents.
If you’re looking for a Brother mobile printer, you can check out the Brother PJ663 PocketJet mobile printer. It offers infrared 1.2 (IrDA), USB 2.0, and Bluetooth 2.0 with EDR support connections which allow an easy link to Smartphones, laptops, and tablets and print high-resolution documents wherever you are. Using thermal technology, the PJ663 offers black and white printing of documents up to size A4.
Another plus factor is that, it doesn’t require toners or ink to print. It supports Windows XP, Windows Vista, Windows 7, and Windows 8.x. For Mac, it supports OS X 10.4 Tiger up to 10.9 Mavericks. It measures 255 x 55 x 30 millimeters and weighs 473 grams. It supports auto power off and can print up to 300 pages on a fully charged battery.
The auto power off mode feature allows the printer to automatically turn off after a certain period of no key operation to help save battery.
