What is Bus speed and function on a computer?
What is Bus speed, where does it reside and what is its function on a computer?
You can take it as a window in a computer through a computer see the memory and performs different task. As in a window some we can look on the other side but it depends how narrow or big the window is same is the case with BUS. It is used to transfer data from one source to other.
Consider the traffic on your roads it the concept just like that BUS need some digits traffic to travel through once destination to another destination. So as the road is wider the more traffic will flow across the road and as the road is narrow then less traffic will pass through it. There may be a 32 bit bus or a 64 bit bus it depends on the manufacture and the customer needs.
I hope now it will be easy for you to understand the whole concept of BUS and its operations.
Notifications
