Due to the heavy load, I reboot my system. It used to work fine before the reboot. After the reboot I received the message that the operating system not found please install. Both the memory and hard drive are working fine. When I tried with a startup repair, I got error code 80004001. How to solve it?
hansmith
10 points
What Can Be Mean Error Code 80004001?
The error ordinarily occurs when you attempt to update an older windows version or running a particular application. When you diagnosed your hard drive, it may be fine to see, but there may be an error logically, which does not allow windows to load.
The error sometimes also occurs due to the poorly configured files in the windows in your system. Sometimes virus or corruption in system files will also lead to the problems. You can also try by running a system file checker it may also help. Sometimes misplacement of hard drive internally will also lead to this error.
