What Can I Do Now To Get Back The Speed?
I use both Windows 10 and Linux in same laptop. I need to reboot it very now and then to open either Windows 10 or Linux. This continuous rebooting has caused my laptop to run slower and slower. The speed is gradually decreasing and it has caused a lot of problem for smooth working. What can I do now to get back the speed?
Answered By 40 points N/A #318743
We can run windows 7, windows 10, and Linux in same PC or laptop at a time and you need not reboot it every time you need to work on either of them. There is an open source software downloadable platform known as virtual box. Oracle VM Virtual Box is hosted by hypervisor for x86 virtualization that is being developed by Oracle Corporation.
Virtual Box may be installed on Windows, macOS, Linux, Solaris and Open Solaris. Install this open source software on your PC or laptop. Run it to open your required windows 10 or Linux in it. This won’t make your computer slow since you will not be rebooting it each and every time and your computer speed remains constant and you can work smoothly with it.
