What can I get from partition bad disk?
Where can I download this for free and what can I get from this partition bad disk? Would this be safe?
Partition Bad Disk can help you isolate and detect bad sectors on your hard disk partition.
It is safe to use and you can also set the properties of your partitions including the size, the positions and more.
But as the other software, you need to purchase it for $9.95. Download it from here.
Software allows you to create healthy additional disk partitions on your computer. If you have three partitions on your hard drive (C,D and E) and you need to create another additional partition F by splitting the storage size in E drive. That’s where the software can be used one additional advantage of using the software is it’s automatically search for the bad sectors on the disk and clean them up.
But remember it’s not a free software and you can download a trial version from the below link:
Partition Bad Disk is your ideal tool for partitioning a hard drive that has bad sectors. It carefully scans the hard drive and in cases where bad sectors are detected, the program isolates the bad sectors so the partition created is free and healthy. It is high efficient and offers a tough error disk scan algorithm.
You can stop the scan at any point and then continue it next time. The program automatically saves the scan result so that you won’t have to scan the entire hard drive again if you wish to continue it the next time. It doesn’t have any limit in the number of partitions created. It also supports conversion of partition from FAT to NTFS.
Partition Bad Disk is not only designed for hard drive with bad sectors but with healthy hard drives as well. These are the hard drives that don’t contain any tracks of bad sectors. A bad sector in a hard drive is a sign that it is wearing out. It costs $19.95 and supports Windows XP 32-bit and 32-bit and 64-bit versions of Windows Vista and Windows 7.
Visit Partition Bad Disk 3.4.0 to download. See image.
