What are the distinct features of Duet Display and how best it be used on Computers effectively? What are the setbacks and demerits surrounding the connection of the Duet Display on Windows 7 or 8 computer as compared to the connection of the same Duet Display software and the MacBook? Thank you.
What can one do to use iPad as Monitor
The Duet Display app is nothing short of amazing, It is unique, Unlike all of second screen apps out there, It lets you connect your iPad via lightning or 30 pin connector, For faster, And less stuttering experience, Setting up Duet Display on Mac is much the same like setting up on Windows, You get to install the companion app on windows, And connect your iPad, It will work immediately as second screen,  There are some minor bugs on windows, But they will be definitely fixed with future update.
