What can Opera Turbo do to help Opera clients in browsing?
I'm having a slow connection on my tablet.
I am using Opera browser.
Is there anything that could help me speed up my browsing?
Do i have to download anything?
I'm having a slow connection on my tablet. I am using Opera browser. Is there anything that could help me speed up my browsing?
I will answer your last question first. No you don’t need to have anything installed beside the opera itself to have opera turbo running. You just have to click on the Opera Turbo button in the status bar below to just enable it.
The opera turbo actually uses a on server data squeeze method. In this actually what happens that before the website is displayed on your tablet it will be compressed via opera’s server and the website will be displayed on your laptop would be much smaller in size hence downloading more quicker.
The opera turbo isn’t effective on fast connections but makes a large difference on slow connections.
Here is an example of an Android tablet that can run the Opera browser, the Amazon Fire 7 tablet. The Amazon Fire 7 tablet doesn’t support GSM communication and doesn’t use a SIM card. It was announced on September 2015 and released on November 2015. It measures 191 x 115 x 10.6 millimeters and weighs 313 grams.
It has an IPS LCD capacitive touchscreen display with 16M colors at 600 x 1024 pixels screen resolution. It supports multi-touch with Fire OS 5 UI. It runs on a customized Android mobile operating system powered by Quad Core 1.3 GHz processor. It supports microSD expandable up to 128 GB. It runs on 1 GB RAM with 8 GB internal storage.
The primary camera supports 2 megapixels and can record video in 720p. It has a secondary camera with VGA support. It has Wi-Fi 802.11 b/g/n, Bluetooth with A2DP and LE, and microUSB 2.0. It has built-in accelerometer sensor. The pre-installed web browser supports HTML5. Java is not supported. It runs on a non-removable Li-Ion battery with talk time up to 7 hours. It is available in black color.
If you have a slow internet connection, your device can have an improved internet browsing if you install the latest Opera browser. Download and install the latest from Opera Browser for Android. Visit with your tablet. When it is already installed, run Opera and enable the Opera Turbo option. It compresses your data which improves your browsing speed while reducing the amount of data consumed.
