What is the compatibility or chrome os equivalent?
Hello fellows,
What is the compatibility or chrome OS equivalent?
I have to ask if the Windows and Mac OS are capable of handling Google Chrome internet browser.
If I install Google Chrome on my Windows 7 starter OS would it be a problem free environment?
Your suggestions will be much appreciated.
Jeremy Jack.
Best Answer by Johnstoon Leen
Answered By 0 points N/A #185515
Hi Jeremy Jack,
Google had developed Chrome web browser for almost all available OS.
You can get it installed for your windows 7 where you can download its compatible version from the Official site of Google.
They also developed one for MAC OS. So you don't have to worry about compatibility issue for this web browser.
Lyana
Answered By 0 points N/A #185516
Hi Jeremy Jack,
Google Chrome is compatible with Mac, windows and Linux under some different requirements.
Chrome Compatibility with Windows Requirements.
Operating Systems: Windows XP service pack 2+, Windows Vista, Windows 7 and Windows 8.
Processor: Intel Pentium 4 or later.
Free Disk Space: 100 MB.
Minimum Ram Memory: 128 MB.
Chrome Compatibility with Mac Requirements.
Operating Systems: MAC OSX 10.6 or Later.
Processor: Intel.
Chrome Compatibility with Linux Requirements.
Operating Systems: Ubuntu 10.04, Debian 6, OpenSUSE 11.3+, Fedora Linux 14.
Processor: Intel Pentium 3 / Athlon 64 or later.
As Google Chrome is always being a most efficient to use.
It always provides a Friendly Environment instead of the problem faced environment.
Well I hope you’ll like my solution and understand the compatibility concept with different OS.
Good Luck!
Johnstoon Leen
Answered By 0 points N/A #185517
Hey Jeremy,
Downloading Google Chrome Browser on your PC is problem free.
The best way to download Google Chrome is from support.google.com
Click on “Download Google Chrome” and choose Run.
Once installed, customize it to your own liking.
If you encounter any issues, go to your firewall and unblock it.
If you find Chrome running slow on your Windows Starter, you can always download the portable edition.
It’s lighter and faster and could be accessed from a USB.
Answered By 0 points N/A #185518
The high-speed Web browser integrated with Google search engine is known as Google Chrome.
Aside from faster response, It is also powered by a custom built JavaScript to run complex Web-base application.
Google Chrome support Windows, Linux and even Mac that allows users to sync their bookmarks, password and stored information with other computers running Chrome.
