I need help on upgrading my computer system for gaming. I noticed that the only thing good (based on my budget) about it is my motherboard (M5a78l-m lx v2). Now, I need to know a good CPU, GPU and other parts needed to make build a PC that is best for gaming purpose with my budget of $150- $400. It will be very appreciated. Thanks.
What components should i buy to upgrade my current PC for gaming?
Hello Maragarete!
Converting your mobo into a gaming pc is a good challenge. It’s a mid-tier level gaming pc. You just need to induce more power or add some good hardware to get efficient gaming experience.
Check first your memory. If your memory placed in your computer already reached the limit for the highest memory you can install then be settled. If you can still add more buy or replace memory to gain more speed. For the graphics card, you need to check the latest hardware that will be compatible to your mother board. There are various video card manufacturer that can give you best results in graphics output. To mention we have Nvidia, AMD, and MSI.
