What computer hardware makes a computer game load faster?
I play an online game called "Dota/Heroes of newest" (title doesn't matter) but there is a loading screen which I take very long to load unlike others. What computer hardware can speed up the performance?
Best Answer by Clair june
Answered By 0 points N/A #81051
Hello, Allison
Three factors that Play a Very Important roll in loading and Processing:  Hard Drive, Memory and Network(Modem, ISP, etc)
I would suggest you to start with your Internet Service Provider to make sure How Many MBP'S are you currently Getting from your ISP. 7.1-15 MBPS is a good One.  Also, to speed up the overall computer performance would be to Upgrade your Memory to a higher one a Memory of 1-2 gb is the best One.  Hope it helps.
Answered By 15 points N/A #81053
When the computer loads a game, it reads data from the hard drive then loads that data into memory then the game is loaded. Therefore to make it load faster, read speed on the hard drive should be as fast as possible. This can be achieved by using an SSD which has faster read speeds compared to hard disk drives. Being able to load the data into memory faster is also a factor, therefore, you should have ample amount of memory and use the fastest memory modules supported by your motherboard. This way, your setup is maximized and you can enjoy your games a few seconds earlier.
