Hi, what is a convert table to CSS software? Is this related to PHP and MySQL server databases? Tell me more about this for additional knowledge this will be very useful for my future tasks.
Please do advise me.
What is a convert table to css software?
Hey Araceliariana,
You should know that there’s basically no point of converting the table to CSS software. It is basically the way through which we use to convert AP elements in Dreamweaver.
Following the way through which you would be able to easily convert your tables into AP elements.
Go to dreamweaver menu –> Modify –> Convert –> Convert tables to AP elements
In different versions, it may under the File –> Convert menu heading.
It will actually, make the positioning of the div tag and make the content absolutely fit in the table cell. If you are using nested tables, you’d most likely see nested div tags afterwards.
