Hello experts,
What is the correct hotkey open tray mac? I would like to know the hotkey for opening the system tray of mac operating system. I apologies for I am just a newbie in this kind of operating system, having a hard time to locate the settings and other features, I wish you can guide me. Thank you.
What is the correct hotkey open tray Mac?
Hi
I will surely help you to solve this problem. Now a days Mac computers have in-built optical drives which is called SuperDrive and it is slot loaded. The tray is always open. You can insert a cd or dvd at anytime and it will read it immediately. If you want to eject the disk, then there is a eject key on the top right corner of your keyboard if you are using a laptop.
