What is the correct way to install 3ds max dcom Plugin?
Posted on - 02/25/2013
I got a toolkit with 3Ds max dcom plugin ant tried to install it in windows XP.
It seems its does not support for windows XP or any other problem has occurred.
I tried to install the dcom plugin manually and get the same error message that I got the same error with windows 7 also.
I want to know is there a way to get 3Ds max files in acrobat (* rh.) format.
Do I need to convert it or can I download it as it is. If I want to convert it how to do that?
Best regards.
