lark yency
20 points
Posted on - 12/09/2012
I have brought a new advent pc and webcam.
But I had a problem, I lost driver disk of webcam.
Then I downloaded the drivers from the net and installed but it didn’t work.
Please tell me what kind of failure with this and tell me correct webcam setup advent pc.
Thanks
What is the correct webcam setup advent pc?
As a matter of fact You didn't mention which model you are using and what was the error message?
So can tell you the exact driver for your webcam. Let's try something to resolve your issue.
First try installing Skype, Yahoo or MSN to check out maybe it will be working fine. Camera only uses for video chats.
If it’s not working fine with these applications try this. Click on Advent Webcam Drivers to visit this page and Download this software to install on your PC.
Its Automatically detect the drivers which are not correctly installed and also tell you the uninstalled drivers.
