What could be the problem with Launcher Pro?
I have downloaded Launcher Pro with extension which will unlock widgets.
It is running smoothly, but when I am trying to change the numbers of home screen page, it asks for restart of software, but after restarting the software the changes is not coming into effect.
Please help.
Answered By 75 points N/A #108435
Hello Cliffered.
Are you sure that you installed the right version of launcher pro for the operating system that you are using? The problem could be as a result of the launcher pro not being compatible for the operating system version that you are using, so will need to check that. You will need to ensure that if the operating system you are using is a 32 bit or a 64 bit, you have the right launcher pro operating system that corresponds to the operating system version that you are using.
Try restarting the application, or restart the computer to refresh the settings, and see if the will help you in solving the problem.
__
Regards
Lee Hung
