Hallo people.
My personal computer has been working very well for a while now. I have made sure that I keep everything at the optimal level, from registry cleaning, hardware blowing and dusting and anti-virus updates. There are times when it gets too hot that I fear it might blow up. What CPU ADM temperature control tools can I use to ensure that the system does not get so hot? Thanks.
What CPU AMD temperature control tools are effective?
Hi Grant,
You seem to be doing a good job in ensuring your computer is working optimally. I would recommend a tool that is not only restricted to temperature readings, it also gives you tons of information about your computer that you might be interested in knowing. The software is Everest home edition, it has a nice interface combined with excellent features.
Here is the download link: http://www.softpedia.com/get/System/System-Info/Everest-Home-Edition.shtml
Hello Grant,
As you have mentioned you maintained your computer very well and you just need a CPU temperature control tool.
Let me tell, you so many software are available in the internet which helps control the CPU temperature. Real Temp software is a good one, it has so many features and you can download it so easily.
Try to get the latest version, hope this will help you to control your CPU temperature.
Thank you.
Hi Grant,
There are two hardware components you need to watch out for because they have a habit of overheating the CPU. These are the system fan and the memory. Incase you have installed heavy programs, computer memory will be struggling to keep up with the programs and this could affect temperature. In some cases the system fan could be functional but at low speeds resulting to the same condition. You can monitor CPU temperature using a number of tools like the CPU thermometer or the Core Temp. They will allow you to see the CPU temperature in real time. These programs are free so try them out.
