What is custom built desktops?
Hi guys,
What are the differences between custom built desktops to brand new laptops and desktops?
I have to get accurate information regarding desktops and laptops for my report and upcoming case study projects.
Also include some additional information regarding the issue.
Expecting some help,
Thank you.
Best Answer by Riley weaver
Answered By 0 points N/A #184985
Hello Timothy Raine,
Hope that my message finds you well.
The custom built desktops is desktops that are made for you based on
Requirements you determined them so they will be different from brand new laptops
The brand new it has static features made for specific quantity.
Of course the custom desktops are better than the brand new.
Here a site for buying a custom desktops https://www.pugetsystems.com/desktop.php
Hope this solution will help you and please let me know if you need anything else.
Kind regards,
Answered By 10 points N/A #184986
Hello Raine,
A brand new desktop or laptop usually configured with the manufacturer’s specification. But a custom desktop means you reconfigured its hardware. It depends on your need. Both laptop and desktop could be customized but in case of laptop once the customized laptop shifted then you cannot customize that. In case of desktop it is much flexible.
You can increase RAM, Graphics power, power system etc, also you can cut the power. Your computers motherboard manufacturer will be give specification and you can change all those things according to that. But in case of laptop you would not be able to increase or cut all this kind of hardware. This is the basic difference between computer and laptop. Custom desktop means its hardware is moderate and brand new means it is company configured.
Thank you,
 Riley Weaver.
