Send me detailed information about DBAse
A database is an integrated collection of logically related records or objects. An object consists of data values describing the attributes of an entity, plus the operations that can be performed upon the data. A database consolidates records previously stored in separate files into a common pool of data records that provides data for many applications.
dBase, commonly referred to as dBase II, with subsequent versions, dBase III, dBase III+, and dBase IV is a Database Management system for microcomputers. dBase has evolved into a modern object oriented language that runs on 32 bit Windows. It can be used to build a wide variety of applications including web apps hosted on a Windows server, Windows rich client applications, and middleware applications.
