What do DCC stands for? What is a plug and play monitor? How to find whether a monitor supports DCC or not? How to disable DCC in a monitor? How to configure the plug and play monitor? What are the benefits of plug and play monitor over conventional monitors? How to create custom resolution other than the one which is available by default from the OC and the graphics driver? Are there any utilities to perform the customization of required resolution?
What is DCC and plug and play monitor
1. DCC stands for Digital Command Control. It is the standard for a system to operate model railways digitally.
2. Plug and play device is a device, with some features that makes the discovery of hardware component without the help of physical devices or users in resolving problems. It is an efficient and most reliable device, which displays the plug and play notifications from the computer. If the program monitors network adapters, if you are plug in or plug out any adapters, it will display the adapter name. We can select the device to start monitoring from the drop down box or by click on monitor all device and click on start.
