Steve Waugh
10 points
Posted on - 09/17/2011
What is the meaning of IP address. Naturally we see an IP address consists of several numbers. What is the significance of those numbers ? Who provides IP addresses? Is there any one who can answer all these questions?
Drothy
What is the definition of an IP address?
Hi!
IP address stands for Internet protocol. This is a unique identification code given for every computer and printer attached to a network. Basically it is a 4 digit number which indicates that what is the location of a user and how to transform messages to and from that user.
Secondly, it shows the region of the user. As every machine on the Internet has its own unique IP address it is of great importance while working in a network environment. IP address is generally provided by ISPs. It is our only identity on the net.
Hope it answers the question.
lee hung
75 points
Hy,
IP means Internet protocol. Naturally we see an IP address when we connect on the Internet. At a short command we can see an IP address.
Go run command > then CMD> then CD then command there ipconfig/all. By this command you will see your PC IP address that comes of a server.
A router basically gives IP to its host. If you command a ping then the IP address; then you will confirm that your LINE is completely OK. Note this is significant on router IP. A router can divide its C Class IP. Router provides its host dynamically or manually what we command on router.
rizza30
These are the answers to all its questions. Help hope.
What is a direction(leadership) IP?
A direction(leadership) IP is an identifier for a computer or device in a network TCP/IP. Networks using the messages of route TCP/IP protocol based on the direction(leadership) IP of the destination. The format of a direction(leadership) IP is a numerical direction(leadership) of 32 bits written like four numbers separated by points. Every number can be zero and 255. For example, 1.160.10.240 might be a direction(leadership) IP.
Connection to a network deprived to Internet needs the use of directions(leadership) IP registered (called Internet addresses) to avoid copies.
Four numbers of a direction(leadership) IP are used in different ways of identifying a particular network and a host of the network. Four regional records of Internet – ARIN, RIPE NCC, LACNIC and APNIC – allocation of Internet addresses of the following three classes.
Class To – supports 16 million hosts in each of 126 networks
Class B – supports 65.000 hosts in each of the networks of 16.000
Class C – supports 254 hosts in each of 2 million networks
What is the importance of the direction(leadership) IP?
With sight to the importance of obtaining a handle in directions(leadership) IP it can be disastrous. The directions(leadership) IP are one of the most important resources(resorts) that must be managed in any network. Every application in network and the device – of the e-mail and connectivity in the file of storage and printers in network – depends on the IP and needs the directions(leadership) allocation. It presents a quite big challenge, but it is to turn into an even major challenge like new basic services as VOIP and mobile networks increase IP needs for allocation, which need allocation more robust, classification and pursuit of directions(leadership). This is known collectively as an administration of directions(leadership) IP (IPAM).
IPAM can they allow to the managers to eliminate the interruptions and the network conflicts, to realize a pursuit of the critical assets and to guarantee the safety of the network providing reports based on a wide range of parameters, including the state(condition) of the direction(leadership) IP (dynamic, static, available, reserved, etc.), names of host, direction(leadership) MAC and DHCP contract of information including lease dates and hour, the remaining lease time, time of the last renewal and much more.
What provides the direction(leadership) IP?
The router is normally assigning the direction(leadership) IP (Internet Protocol). But the team(equipment) also can form the IP if it is indicated or needs a direction(leadership) static IP.
