What is Desny’s Reverse Electrovibration?
Desny's Revel device has brought an awesome feeling. How will it effect on human body?
How many devices will be needed in this regard?
Hello Edwaard,
The Disney conducted a research that left it thinking that it can be able to go on better using Tactile as well as Haptic touch displays with the use of electrical fields to add sensation to about everything you can be able to touch. With the utilization of Reverse Electrovibration, the REVEL does its work by simply strapping an electrostatic signal generator to someone's body, so that in the event that you have contact with an object on the same electrical plane, the low-level field will be able to be alter in order to create friction.
It is expected that this technology will revolutionize touch screens, and as well add a whole new level of feeling to the augmented reality and as well aid the blind people feel their way around.
Carl
