Hi guys. What development tool PHP MySQL would you recommend? I need a tool with a debugging capability to find bugs in my source code. I also need to test the stability of my web application. I'm using a PHP 5 source code. Thanks.
Hi Donna,
In my opinion, the best solution for you is to buy Adobe Dreamveawer CS6. Surely, this is the best program for web developing. This program has support for PHP, CSS, HTML, JAVA, Action Script, Flash, MySql, etc. In this program you can test the stability of all your applications.
If you are looking for free solutions , than you can try with "PSPad". It is completely free program with support for HTML,MySql,PHP, etc.
