What is the difference between wave table synthesizer and Frequency Modulation synthesizer in relation to the computer sound system? Which among wave table synthesizer and frequency modulation synthesizer deliver complex sound from simple computer components? Which among the two is more economical? In term of quality of sound, which produces more quality sound?
What is the diff between WT synthesizer and FM synthesizer?
Hello Maurice B Rodgers,
                        WT (Wave tables) synthesizer is a component device that is used for digital recordings of real instruments, which are stored in ROM.The FM synthesizer is also a component device based on the synthesis technique called frequency modulation. FM synthesizer can create both harmonic and inharmonic sounds. WT synthesizer is more expensive than FM synthesizer because WT synthesizer needs compression technology and ROM. WT synthesizer produce a richer sound compare then FM synthesizer.Â
