What is the difference between ivt bluesoleil 8 and version 10, is it worthwhile upgrading? Does version 8 entitle me to a free upgrade to version 10? Which versions can be upgraded to the latest version for free, if any? I like using my Bluetooth for audio purposes sometimes.
What is the difference between ivt bluesoleil 8 and version 10?
Hi Bobbye,
BlueSoleil 10 is based in BlueSoleil 9’s features and it is taking advantage of Bluetooth 4.0 low energy and it is also compatible with Windows 8. BlueSoleil 10 had improvements in their Windows based Bluetooth technology and applications. BlueSoleil 10 gives a way better experience with wireless Bluetooth. It also supports dual mode dongles, enhanced sound for A2DP and SCO. It now support most Symbian Operating system.
