anonymous
7060 points
Posted on - 10/24/2011
Hi Experts!
I am running MS Word and want to know the differences between merge and split cells. How can I merge cells in creating a table? And how can I split multiple cells in a table? Any help will do.
Sean J.
What is the difference between merge cell and split cell?
Hello Mdarifsadik!
Merge cells is the opposite of split cells. In MS Word, the split cell feature allows you to split cells into two or more cells. On the other hand, the merge cell feature allows you to combine two or more cells in the same row or column into a single cell.
One example is merging several cells, horizontally to be able to create a table heading that spans several columns. I hope that I enlighten you about the difference of split cell and merge cell. Have a wonderful day!
Sean
lee hung
75 points
Hi Mdarifsadik,
Merge cells is a feature in Microsoft Word that allows you to join many cells in a table into one cell. Say you have five rows in a table which you find not useful and you would like to convert them into a single cell which you want to use, you will simply merge the five rows into one.
You can find the merge cell in MS Word 2007 by highlighting the cells, then right click on them and choose merge cells as shown in the diagram below:
Split cells on the other hand is a feature that will allow you to divide a single column or row into more rows especially if you would like to fix some data in between the existing rows or columns. Just like the merge cells feature, to split a row or column into many more, right click on the row or column where you want to place the additional cells, and then choose split cells as shown in the diagram below:
Hope this helps.
___
Lee Hung.
James10
Hello Mdarifsadik,
I would like to share with you the difference between the merge cells and split cells in word. Merge cells is the act of combining two or more cells in a given column or row and making the team appear just as a single cell. This is mostly used when you want to make a given column or row a single cell. The procedure to merge cells is simple.
Select the row or column for which cells you want to merge.
Click the table menu and select Merge cells.
Split cells are the exact opposite of merge cells. This allows you to split into more than one column previously merged cells.
The procedure to split previously merged cells is simple too.
Select the cells you want to split.
Right click and choose Split cells.
Specify on the number of columns and rows and click ok.
mat234
As it relates to tables or spreadsheet cells; merging refers to combining multiple cells into one, splitting refers to dividing a single cell into multiple cells.
lee hung
75 points
The difference between the two merge cell and the split cell is the merge cell you can cartel the two or added cells from the same row and the column in to the single cell and then the split cell incomes separating a cell into 2 or more cells and the merging just simply linking 2 or added cells to make a only cell.
For example of the merge cell you just create a table by horizontally in the spans several columns. The split cell you can in the word 2207 boards just simply removing the line to the divides them and you simply can draw a line by parallel or perpendicularly from the cell.
Merge Cell means combining two or more cells into one large cell that displays the contents of the first cell and Split Cell shows distributed cells' contents into adjacent cells.
The below content described How to Merge Cells
Merge Cells
Select the last column.
This is the one you just moved.
Right click on the selection.
The context menu for tables appears. The commands listed vary, depending on what is selected.
Click on the command Merge Cells.
The contents of all three cells become separate paragraphs in the combined cell. The cell background is the same as the top cell in the column, but the paragraphs kept their own text formatting. Is this getting complicated??
 Save.
[table3-Firstname-Lastname.docx]
The below content described How to Split Cells
Split Cells
While the column is still selected, right click on the selection.&bsp;
The context menu appears again, with different choices.
Click the command Split Cells.
The Split Cells dialog appears. You must choose how many rows and columns you want to split the cell.
In the Cells Split dialog, set:
   columns = 1
   rows =        3
Merge cells before split: checked
Click on OK to close the dialog.
You are back to three cells in the last column.
But, the previously merged text stayed in the top cell and the row height for the first row increased to hold the three paragraphs.Â
So, Split Cells is not at all the same as undoing the merge.
 Save. [table3-Firstname-Lastname.docx]
Really useful information. It helps me to clear my doubts.
Thanks for all the solution providers.
