What is the difference between OK and APPLY?
70 points
Posted on - 02/20/2015
I run my PC on Windows 7 and I often change the settings of my PC.Â
' Do you want to change the settings?' click on OK.
' Do you want to change the settings?' click on Apply.
So, what is the difference between OK and Apply on any version of Windows though they have similar function?
