What is the difference between slide transition & slide show view?
Hello again,
What is the difference between those two? Well, to be honest, you’ve kind of mixed apples and oranges JSo, you’re doing some cool presentation, want to sell something. And you decide – Hey, why wouldn’t I do some cool stuff like when I go to the next slide, my previous slide flies away from the screen, and the other one enters jumping on the main screen? Or maybe something else? When you’re doing transition between slides, that animation is called slide transition. Slide show view is when you’re doing presentation, and you decide that you won’t allow that people see all of your slides on the left (spoiler alert!!), so you put one slide all over the screen with F5. That, my friend, is the difference.
Slide transitions on Microsoft PowerPoint are animation-like effects where slide show is used to move one page to the next during presentation. It plays over a period of time depending on how you would like it to be shown whether slowly or faster than the usual effect. Now don’t get confused between slide transition and slideshow. They may be used both for animation-like effects when creating on-screen presentation, but slideshow on the other hand is the display of series of either information or pictures or even instructions that the user has created to make their work more artistic. Either way, both Slide transitions and Slideshows on Microsoft PowerPoint are used to make ones work more interesting to the participants or the viewers.
Thank you Tanok Bloran for your solution! I really appreciate it. now i know the difference between slide transition and slideshow view. Many thanks TechyV!
