Mia Molly
20 points
Posted on - 11/16/2012
Hi guys,
What is the disadvantage of photoshop win7 starter version? It is good to know all the ability of the software that we tend to install in our computer system. I got this photoshop and wants to be aware about the feature and added functions. Your suggestions will be much appreciated.
Expecting some help, thank you.
What is the disadvantage of Photoshop Win7 starter version?
Disadvantage depends on the Application. Most of the time Starter versions and Portable versions are used by graphic designers in case of an emergency where they cannot find the software and a smaller size version is available online which can be downloaded quickly. If you are hoping to use Starter or Portable versions for large scale graphic designing it may not be a good approach since most of the time those versions crashes.Â
