What is disk defragment in windows ?
Hello Dear,
Thanks for sharing your problem with us.
Dear disk defragment is very useful tool of windows.
Defragment means to sort files near or close to each other.
When we copy files into hard disk then computer saves them randomly, not in a sequence.
It makes computer hard to work with.
But when we run defragment tool. It sorts all files in sequence and it also increases the performance of computer and disk space.
I hope it will help you to understand your question.
Thanks
Hi Mr. Peter Jackson,
You can use disk defragment for the defragment the hard disks and USB storage device.
Fragmented disk may be causing for slow your computer. Disk defragment is a tool which can be use for reorder the data in the hard disk. That will helpful for fast data access and increase the efficiency of your disks and drivers.
You can run it manually by right clicking on the disk drive and click on the properties and select the tool tab.
Thank You,
John Major
