nimzaj
Posted on - 08/14/2011
I was signing up an account at a particular site in the internet and I was not able to create an account.
Whenever I click on SUBMIT button, it says there, "enable cookies"?
What does this means and what to do with it?
Please help. ^_^
What to do with “enable cookies”?
Hello Nimzaj,
Here are the tips to enable cookies of your browser, see instructions below;
Open Internet Explorer
Go to Tools, Internet Options
Click Privacy Tab
Go to Advanced Tab
Check the box on Override Cookies
These steps will let you access websites that requires to enabled cookies that a web browser has the control. You will have the ability to either block, saved and or allow cookies to save in your browser. The main purpose is to let your browser remember those set of data stored in your Internet Explorer.
Firefox 3.0
Use the 'Tools->Options' menu item, then choose the 'Privacy' tab. Here you can choose whether cookies are enabled, and if so how long they will persist. You can also use the 'Exceptions' button to override the settings for particular websites.
