What do I need to get avast for iPhone?
I want to have the avast antivirus in my computer installed to my iPhone as well. What do I need to have in my iPhone to get avast for iPhone?
Hi There you are,Â
You want to install in your iPhone the same antivirus software installed in your computer. That is not possible. You can do some other things instead.
They are:
1. Use iTunes and scan the iPhone files with the PC avast antivirus.
2. Download an antivirus to the iPhone that is made for the device.
Avast mobile security is one of them. You can try that. I found a link for you. Choose and download to your iPhone and enjoy it.Â
I don't think that there is Avast available for the iPhone or Avast has any plans to develop this antivirus on iPhone. For a reason that there are very few Malwares or Spywares for mobile phones.
But you can try VirusBarrier that lets you scan your iPhone to manually scan your device for malware. Just go to the iPhone App Store and search for VirusBarrier. You can buy the app for only $0.99.
