What To Do If LG Smart Tv Not Connecting To Internet?
It is common issue with manufacturers of LG TV’s , Sony TV’s etc. that the WIFI settings cannot be saved. What to do if the LG smart tv not connecting to internet?
You can enter you networks SSID information instead of selecting it from the list. You can save your setting and when you turn you LG TV on the next time then the network will be automatically detected. On your 3G smart LG TV:
1) Open the network settings.
2) Click on Network connection.
3) Choose from the wired or wireless network connection.
4) Press on Start connection.Â
5) Select your network and then click on Set expert.
6) When prompted choose the type of connected network.
7) Click on the ‘Enter the SSID’ option.
8) Using the keyboard type the name of the network.
After entering the username and password you will be asked to write the IP address. It will save the settings automatically and it will redirect you automatically next time you login.
