ashle vega
Posted on - 11/06/2011
I am utilizing OUTLOOK 2007 Calendar, and my past scheduled times disappeared. I explored to view last year’s meetings however they are alll deleted! Does anybody recommend guidelines what to do? I do not sync with any computer, please advice.
What to do on Microsoft Outlook 2007 Calendar disappeared
Helo Ashle,
I suggest you to examine both exchange server and outlook to troubleshoot the issues of missing or disappeared schedule on your outlook 2007 calendar. You must obtain MS Office srevice pack 3 to be able to resolve issue. I also suggest that you have to use the same version of the outlook which your clients have been using. Make sure that the outlook that you are using is supported and updated or is not expired. You should also ENABLE the deleted item recovery. You can visit the link below to know more about recover deleted item recovery.
https://support.microsoft.com/en-us/help/246153/how-can-i-recover-items-that-i-have-hard-deleted-in-outlook
I also suggest you to use the log in features of MS Outlook. Good luck! I hope it helps.
-Zorian
