What to do once my free trial has expired
My avast free trial is about to expire and I don't know if I will be charged by avast once my free trial is expired.
If you are using the free trial any software or application, yes it will surely have expiration but you don’t have or you will not pay anything since it is for free.
You will only have to pay if you buy the full version of it, like in your Avast anti-virus free trial. After the expiration, you cannot use it properly or it will not be updated.
You can buy or downloaded different anti-virus in the internet, you can choose what anti-virus that you want to install in your computer.
Hi
Every company gives his anti virus product to be used by peoples at trial period in the beginning to know the response. It is because the users get use to. Don't get scared it wont charged you. When the trial period gets expired. It will start prompting you a message to buy it. If you want to buy then they will charge you for the anti virus. If you don't want to purchase it will be your decision. So take this decision by yourself if you are satisfied with the anti virus.
Normally what will happen after expire of avast is, its automatic update will stop and provide notification to buy full version. You can uninstall the expired application using uninstall option in the application or through the remove application in control panel. Then install new version of avast. The new version of avast free antivirus is 7.0.1474. You will not charge by avast.
