kris marky
Posted on - 11/14/2011
I want to start my SQL Query or DML Statement as a Web Service. I already search and read some guides but I wasn't able to followed it correctly. I have Oracle Call-In Web Service Installation or Database Web Service and I need to know how can I implement this with SQL Query. How to call Oracle SQL Query as a Web Service? Can anyone help me by sending resolutions with a much simpler terms?
Thank you.
dean78
Web service client code that runs in oracle in written in SQL or Java. which calls the external and internal web services. you can also call a service with java code written for webs service. following methods are used to call the web services code written in java.
1. SQL and PL/Sql Call Specs (start web service with user defined function, jpublisher generate this, with a variable or directly with SQL statement.)
2. Java proxy class (Jpublisher generate a client proxy class, in this Java API is used for JAX-RPC, no need to look in UDDI registry, work on request of SOAP class with desired parameters.)
3. DII Over JAX-RPC.
This can be performed using the JPublisher utility available in oracle Application server. Below are the sequence of step and a sample example (attached) on how to expose a SQL statement as web service.
1) Create an Oracle Object Type in oracle database.
2) Create the Body for the Oracle Object Type in oracle database.
3) Create a oracle table that hold the objects in a table.
4) Insert data into the above created table using the PLSQL code.
5) Create a Java wrapper class using the Oracle JPublisher using the below command. jpub -user=USERNAME/PASSWORD -methods=none -builtintypes=jdbc -numbertypes=objectjdbc -usertypes=jdbc -sql address:Address:MyAddress -package=sample.jpubs THis will create a Java Interface class called MyAddress. This class belongs to the object Sample.jpub
