What to do when my computer freeze?
Hi there!
My suggestion for you is to remove other applications a program that unused. It only occupies some of the memory that is why your computer is running too slow. And I have here some solutions to fix your problem. Do any of the following solutions that given.
Solution 1: RUNDLL error is because dll is missing or corrupted and that is about having virus/spyware. Have you tried to scan the whole computer? If not, better to scan your computer with your updated anti-virus. You have to update the anti-virus before you proceed to scan your computer. On your anti-virus, click the Tools tab and select update and wait for a second. When updating is done, proceed now to scan your computer. After the scanning, look for the scan result. If some of your programs/applications are infected by virus, better to remove it. It can infect more of your programs/applications.
Solution 2: RUNDLL error can be the cause why your computer performs slow and hang up. Clean your Registry will help you to resolve this problem. I will give you the steps, follow these steps:
Run your computer into safe mode
A. Restart the computer and press F8 key during the loading startup, then in the Windows Advanced Option select Safe Mode and hit Enter.
B. On startup, the Desktop dialog box will appears and you are going to select YES button.
C: Press the Windows key -> click Run -> type "regedit" then hit Enter.
D: Click the File tab, -> select Export and Type the name for the backup file then click save.
E: After creating a backup of your registry, -> click on the (+) sign to expand the HKEY_ LOCAL_MACHINE then scroll down, -> click (+) plus sign of the SOFTWARE.
F: Same steps to locate the MICROSOFT and find WINDOWS and locate CURRENT VERSION then find RUN.
G: Press Delete to get of the located files
Before you think of deleting a file make sure you first find out what the file is about and if needed Google for it.
Restart the your computer after you close the registry
Solution 3: These methods is to avoid computer slow performance. You have to perform Disk cleanup & Disk defragmenter. They are recommended to do regularly, it helps you clean and compress files. Disk cleanup helps you to free up disk space on your hard drive.
Follow these steps for Disk Cleanup:
A: Run the computer into Safe Mode, follow the steps in Solution 2 at A-B
B: Press the Windows key -> click Run -> type "cleanmgr.exe" then hit Enter.
C: Disk Cleanup dialog box will open, -> check all the check box on the Files to delete.
D: Click OK > click Yes. The disk cleanup is cleaning up necessary files. Then after it clean the files, the dialog box will automatically close.
Then let's proceed now with Disk Defragmenter.
Solution 4: Disk Defragmenter helps you to increase the speed by rearranging files that stored on your hard disk.
Then after you perform the Disk Cleanup, Let's proceed now in Disk Defragmenter. Follow these steps:
A: Press the Windows key, select All Programs, select Accessories, select System Tools, select Disk Defrgmenter.
B: Disk Defragmenter window will open. Then right-click the local drive C and select Defragment and wait for a minute and when defragment is done. Then after, restart your computer.
Solution 5: Other solutions is to remove the Temporary Internet Files, History a cookie to avoid the slow performance of your computer.
Follow these steps:
A: Press the Windows key > Control Panel – Select Network and Internet Connections category > pick Internet Option icon.
B: In the General tab, check the Delete browsing history on exit check box and click Delete button.
C: Kindly check all the check box, but if you don't want to delete Form data or Passwords don't check. The important to delete is the Temporary Internet files, History and Cookies.
D: then click the Delete button > after deleting the files click OK.
