What Do You Mean By Machine Learning?
What do you mean by Machine Learning? What are its various techniques/methods? Explain some areas where Machine Learning techniques can be applied.
Machine learning is a process where the prediction of outcomes is done with the help of data which has been provided. It is a part of Artificial Intelligence (AI). Computers are trained to predict results as per provided data, and not based on any equation or model. With the advancement of Machine Learning, computers will be able to decide what would be the end result based on previous behaviors and patterns of data. When an equation or a model cannot be designed for a particular situation or coding is impossible to decide the outcome of a specific situation, it is then that Machine Learning comes into the picture.
Consider the following examples:
E.g. Bank ATM’s these days are implementing the use of facial recognition techniques to prevent frauds during any transaction.
Some methods of Machine Learning are as follows:
Notifications
