Gina Bruce
Posted on - 09/26/2011
I am working as a personal secretary. I happened to have this error and lately, I do encounter this many times.
Why is this happening?
How do I fix this?
Please provide me also some instructions so that this could be prevented from happening again.
Error
A Runtime Error has occurred.
Do you wish to Debug?
Line:14
Error: Object expected
Yes No
Jenny09
What do you mean by Runtime Error?
Hi Gina,
Runtime errors occur because of errors in the code of the program that occurred, when a particular scenario has been met that were not foreseen during the coding phase of the application. The error code generated by the runtime error usually gives a clue as to what specific error occurred in the application and how it can be fixed.
For a runtime error code of 14, this means that your application was not installed properly. To fix this error an update must be downloaded or you must reinstall the application to fix this program.
Hope this helped.
Regards
