hugh egnor
20 points
Posted on - 02/21/2013
I always use Acronis True Image for cloning and backing up my HDD.
The problem started when I upgraded to Windows 8 and I'm having an Error#1314.
It worked fine on my Windows XP 64 bit.
I have 6 GB SATA Western Digital HDD.
I need help in Acronis image error.
What does this Acronis image error mean?
Hi Hugh,
I think you are having this problem because the task was created as a different user account. Having error – 1314 you’ve to delete all scheduled tasks with the ‘task zap’ command and Acronis scheduling utility. Now recreate the tasks using Acronis backup software.
I hope the issue should now be resolved.
Good Day.
Good day Hugh,
Regarding your problem have you tried updating the Update Acronis Schedule? Updating the scheduler might solve your problem.
Here are some instructions that can be found in the Acronis Knowledge base on how to update your scheduler.
Updating Arconis Scheduler
Just follow the instructions properly and your issues will be solved.
