beth86
Posted on - 09/19/2011
Hey, can anyone help me,
Anyone has this kind of the error message encountered?
Is like kind of annoying since it only gives me a question mark.
There is no at least one word to explain what happens.
I am just doing my project, and suddenly that warning appears.Â
After Effects warning: [?]
Thank you very much for your assistance.
What does this adobe after effects error trying to tell me?
After effect error showing because of some wrong command or missing plug-in. Install some plug-in can be solved this problem. There are many plug-in for after effect on the internet. Just collect some and install or replace with others.
If in your computer you install some similar application program in a same time then uninstall one program, this problem occurs. Similar application share similar file they have and uninstall one program can take that similar file with it. So this error shows.
Other option is to uninstall this application program and use some pc cleaner software and then reinstall it again. It will recover the damage of after effect site.
